M923A2 Turn Signals and Brake Lights
Navo
Chesapeake, VA
I have been driving around and haven't had any issues. Until the other day, when you put the switch in the brake light mode (one turn to the right) the turn signals do not work. The light comes on at the indicator when u pull or push for the signal but nothing happens. Also the brake lights don't work at the rear of the truck. If u go to the second position for the headlights and parking lights they seem to work but no brake lights or turn signals. Anyone have thoughts on this?
1,168
Bulbs good?
Suprman
661
Stratford/Connecticut
If the switch stays solid green you might have a bad control module or a bad connection somewhere. You need to manually check all the Packard connections and then test each bulb and go from there.
juanprado
2,737
Metairie/La (N'awlins)
Sounds like 2 issues.
stoplight switch on the inside of the frame rail by the tank is suspect for brake lights especially if the running lights come on but no brake.
Turn signal assembly sounds like issue #2. Many members have reported sticking contacts recently in those units. Several folks have opened them up, cleaned the contacts, and reported success.
