scrump
- 0
- 1
- Danville ca
Hello Fellow MV'ers!
My M923A2 was running like a top. Then it sat for a few months, and now, with a fresh set of batteries, it won't start.
Engine is primed properly
Cranks strong
Turns over with ether, but won't continue to run without it
There is no fuel leaving the fuel pump (I detached a fuel injector on the top of the fuel pump and none comes out when the engine is cranking, I assume it should).
The kill switch is confirmed off
The throttle solenoid was removed years ago and hasn't been a problem at all.
I ran through the troubleshooting manual to no avail.
Ideas?
Thanks!
mark
Cranks strong
Ideas?
Thanks!
mark
