M925 A2 very disappointed in ability
M35A2-AZ
436
Tonopah, AZ
There must be 50-75 MV owners at our local lake. Deuces, 5 tons, 20 tons. The surrounding area is all desert sand, thick, deep sand. I have not seen one, not one vehicle make it up the sand dunes. Deuces do better then 5 tons. The bigger and heavier the vehicle, the less it will float on top of the sand. Sorry to tell you, but its just not made to climb in the deep sand like that. Most of these trucks had a hard time getting up this small hill. Good luck.
That is a cool shot of all the MV's.
silverstate55
Unemployable
2,130
1,090
UT
I have found that airing down really helps a lot but many folks don't want to go through the hassle. It takes a while. Some of these folk store their truck in the area so I would think there would be little need to air up. I drive up there from El Paso so I am there for 2 -3 days minimum. I air down as soon as I get there and air up just before leaving. Also, some do not air down enough, especially in the lightly loaded rear tires.
Additional weight is not a bad idea but tough to do when you are out there camping, a hundred miles from home. Whatever is back there will get beat to .... , not if but when it does start hopping. There is plenty of sand to shovel into the bed though, if you are really feeling froggy.
True, but where there's a will there's a way. I've gone a lot farther in 2wd trucks than anyone ever thought possible simply by adding weight to the rear and picking proper lines off-road. 50-lb water softener salt bags are durable for short trips and cheap enough to justify buying several hundred pounds' worth to make rear suspensions flex properly. Sandbags are also cheap but involve a bit of labor to fill...but can be filled once on site, placed strategically in storage areas to provide weight for traction, and emptied before your trip home to save on fuel. I always secure weights so that they don't get thrown around; tie-downs, ratchet straps, and even chains are fairly inexpensive at Harbor Freight. My Deuce now has an additional 220+ gallons of fuel storage in the bed, a large truck toolbox, two spare tires/wheels plus a tire crane, and still has room for cargo...but this adds a lot of beneficial weight off-road and I typically don't have to add anything else. I find that the suspension flexes quite well with this added weight and I get virtually no wheel-hop with it. YMMV.
At least once a year I join a group of co-workers for various off-road expeditions through Death Valley; most involve at least one winching point and LOTS of sand/rocks, so airing down properly is a MUST. Inexpensive valves can be added to valve stems to speed up the air-down portion, and air hoses with quick disconnect chucks can be made on the cheap with used gladhands for airing back up. I've had to fix too many parts broken in the past from wheel hopping, bouncing over rocks, etc...so airing down and managing weights on a vehicle are FAR easier than expensive and/or time-consuming repairs later from taking the earlier shortcuts.
But I agree with you; some people don't want to go through the effort and will pay more later, that is part of the learning curve.
bill2444
cheboygan/mi
I've managed to out-climb a humvee before in my stock deuce with 8 psi in the stock ndt's duals on some fairly steep sand hills. In fact I came back a few weeks later in my pick-up to try it. I couldn't even make it to the approach of the hill at street pressures.
In the sand, max pressure I would run is 12 psi. Anything more than that= no floatation. Just be mindful of rolling a bead off the rim.
VPed
315
Clint, TX
Specific PSI numbers are flakey to use across the board. The specific tire, wheel, and weight needs to be factored. I have 395's all around with stock deuce wheels. the front wheels have been widened by 3 inches. I usually air down the front tire on my deuce to 20 PSI. That produces a noticeable bulge and significant flotation. The rears really like 8 PSI but that is dicey because I have spun a tire on the wheel at that low a setting. Not good with tubes. I am wanting to change to MRAP wheels with beadlocks and then it think 15 on the front and 5-8 on the rear would be really nice.
The five ton being heavier needs more pressure over-all.
