- 2,645
- 2,127
- 113
- Sunman Indiana
So... I've promised several people I would get this done for some time now. It may take me a little while, but I'm going to get pictures up, of my install of an old Knapheide manufactured, Knaphoist, KH-2520L that I found on the web for $400.
I also ended up buying an old 15' dump bed, but decided at 6000lb it was too big, and heavy. I also started thinking I wanted to keep more of an original look to the truck.
I ended up reselling this bed for what I paid for it.
Hmmm... all my pictures of just the hoist seemed to have vanished!
This is the best overall shot of the hoist I could find, as it was when I bought it. ![IMG_1831.jpg IMG_1831.jpg](https://www.steelsoldiers.com/data/attachments/452/452674-d4663423b62639d292167a09fa7eaf3c.jpg)
Lifting the bed off so I can start test fitting.
I put the front tandem up on blocks, with the rear just touching the ground, so I could check for interference at full articulation.
You can see where my chains are hooked around the hoist, that is the upper pivot on the end that attaches to the bed. The slotted female portion that goes around these and mounts to the bed did not come with the hoist so I'll have to guesstimate on it's design.
This cartoon is all I could find of what it was supposed to look like.
You can see I have the rubber axle bump stops compressed fairly far with the weight of the truck.![IMG_1839.jpg IMG_1839.jpg](https://www.steelsoldiers.com/data/attachments/452/452687-0612898ea263447bea70b0041d4cad2b.jpg)
The hoist weighs 880lb as shown. I'll end up adding about another 75-100lb in the bed mount.
This is about as far back as I can go, the transfer case u-joint is just off to the right of the picture. This will put my dump angle at about 50 degrees. I considered moving the hoist forward as far as possible and shortening the back of the frame 16-1/2" to get more lift capacity and angle by increasing the rear overhang. I decided this was more involved than I wanted to get right now and may need to remove the spare tire and move the bed forward later to get more weight on the front axle anyhow. ![IMG_3258.jpg IMG_3258.jpg](https://www.steelsoldiers.com/data/attachments/452/452695-49e9488a34229735d2245ab888575216.jpg)
The original bottom stop turned out perfect on the crossmember.
![IMG_3333.JPG IMG_3333.JPG](https://www.steelsoldiers.com/data/attachments/452/452690-bb8ed1bbcffb66c2020bff6dfab0f096.jpg)
![IMG_3334.jpg IMG_3334.jpg](https://www.steelsoldiers.com/data/attachments/452/452668-6d31ce00df02055c786ce4836fdde9d8.jpg)
![IMG_1830.jpg IMG_1830.jpg](https://www.steelsoldiers.com/data/attachments/452/452675-d85841e2ea77aca50c5a13257400011d.jpg)
![IMG_1832.jpg IMG_1832.jpg](https://www.steelsoldiers.com/data/attachments/452/452682-2d6770bd37bfea52e954c9d88e6d5416.jpg)
![IMG_1833.jpg IMG_1833.jpg](https://www.steelsoldiers.com/data/attachments/452/452683-ad75ae127a8c706dffb321f53769ddbf.jpg)
![IMG_3335.jpg IMG_3335.jpg](https://www.steelsoldiers.com/data/attachments/452/452684-6df8bc591c81b61ca28b8d42ac0ddf1b.jpg)
![IMG_1838.jpg IMG_1838.jpg](https://www.steelsoldiers.com/data/attachments/452/452685-7e55947f49abcdc77b3eed5926d2a73d.jpg)
![IMG_1834.jpg IMG_1834.jpg](https://www.steelsoldiers.com/data/attachments/452/452688-23d94a734a8774420802175b76190d4f.jpg)
![IMG_1836.jpg IMG_1836.jpg](https://www.steelsoldiers.com/data/attachments/452/452689-d17ebdf7fb8185f034de7f742ba1f2d4.jpg)
![IMG_3336.jpg IMG_3336.jpg](https://www.steelsoldiers.com/data/attachments/452/452694-8181e5bd95b0fc602cf29c15b3fa51b6.jpg)
