M925A1 Hydraukic Pump Question
4RECOVERY
MOUNT CARMEL PA
New here to this forum. GREAT PLACE! I have a 1985 AM General M925A1 with the front hydraulic winch. Several things I am trying to find out. Does any one know the GPM flow rate for these pumps, the PSI the pump puts out and at what engine RPM ? The control valve under the cab for the winch changes the direction of the flow for in or out operation of the winch. Is there a double valve that can be used for both operations to control the front winch and also to direct hydraulic flow to the rear of the truck to operate other equipment. Any information & ideas would be helpful. Thanks, Daves-l1600.jpg
Jbulach
2,392
Sunman Indiana
Welcome aboard!
The pump is capable of 27gpm and 3000psi at 1800 engine rpm, but is regulated down to around 1750psi due to the limitations of the winch.
If this link works, check out my dump bed build for one of many options on how to divert your hydraulic system.
https://www.steelsoldiers.com/showthread.php?164018-M925-M925A2-dump-bed-hoist-install
I think theres some info in my snow plow build also, as well as info on other members builds.
https://www.steelsoldiers.com/showthread.php?162850-M925A2-snow-plow-install
