M925A1: Troubleshooting Failure to Charge
SchroedingersCat
NJ, USA
Recently noticed the voltmeter was reading in the yellow. This sounded like a voltage regulator problem, so I replaced the regulator on the back of the alternator. Even found debris from the regulator in the brush cavity of the alternator...that bode well for a correct fix. BUT NO, I started the truck, the volt meter showed in the green (good!), but after a few minutes the voltage started to climb (bad), just before reaching the red, the meter just dropped back to yellow (bad!). Either I blew the regulator again, or something else failed. Possibly the PCB, though I can't figure out how/why that would cause the problem. Anybody got any ideas? If the PCB, how does that fit in with what happened? Thanks.
74M35A2
342
Livonia, MI
The stock military alternators have several different common failure modes, their technology and materials are from generations before it, let alone expensive to repair.
Any modern alternator will run circles around it in reliability, possess better cooling, have built in fail-safes, they adapt fairly easily, and can be had new for $80 shipped with 1 year warranty plus a $15 pulley.
I do prefer the look of the stock military one, but once it comes down to it leaving you on the side of the road or missing your favorite car show, not worth it.
