tractors0130
- 3
- 0
- Joliet, Illinois
I just finished installing a 21SI Delco style single wire 70amp alternator on my M925A2 with the 8.3L Cummins and single belt after the original 60 amp Leece Neville fried. Install was pretty easy, just had to put a slight notch in the upper factory bracket with a short spacer and lengthen the lower brace by 1.75" to use the original belt. The original style alternator could always be put back if someone wanted to. I need to put a little longer bolt in the rear upper alt. mount to brace the heater hose, paint the bracket and spacer and put some rubber guards around the rear alt. connections to protect them. As seen in the pics. it's charging at 28.2 volts with 14.1 volts on the "R" terminal. Instructions say not to exceed 4 amps on the "R" (relay) terminal.
