MIDDLEMAN
- 8
- 8
- Arlington/Washington
As a newbie where would be the best place to post this? The dive shaft/coupling between the two rear diffs, right where it enters the diff. is seeping a bit on both. (On a regular pickup rear end, I would say it is a bad pinion seal) I am sure I can get it apart, but any tricks? Is this a common problem? Best place to find the parts needed?
