M925a2 Power Surge
Buffalobwana
180
Frisco Texas
Place holder for near future secret weapon.
My perfect running stock 6CTA8.3 complete engine may be available for sale as early as later this month if my plan works out as intended.
Stay tuned. Those in the know, pretend you don't know...
4-07-17 engine for sale
11-16-17 engine still in truck.
You could litetaly make a real live person (9 months gestation) in less time than it will take this engine swap to happen. Just sayin. Think about that.
Carry on gentlemen.
74M35A2
341
Livonia, MI
Just proved out the pedal position sensor. Plan now is to leave the stock pedal, and just link the throttle rod to a used Dodge Ram Cummins accel position sensor. This is because the floorboard in the cab is sloped at a 45 degree angle where the pedal resides. Most electeonic pedals mount to a flat floor or the vertical firewall. 45 degree ones do exist, but are harder to come by used. By using the stock pedal, I can keep my throttle lock.
With a regulated 5V power supply into the sensor, it spits out 0.5V at idle, and sweeps to 3.8V at wide open. The Cummins ECM calibrates this range if you do a power-up and depress the pedal without starting the engine.
This is the only external piece needed to run an electronic diesel engine.
CDF7E1D9-8214-4552-B111-C65D18E81F75.jpg628DA812-C299-4260-A5D1-97C7D879C8D3.jpg4FD4DA95-FC6F-42C0-87FE-F3A1872820BC.jpg
74M35A2
341
Livonia, MI
Test ran the engine today. First time on all 24v system, QSL fuel filter setup, Jake actuators, clutch/trans installed, and Dodge Ram accelerator sensor. All worked well. Power train is complete and ready for install over Christmas break. Test ran without exhaust manifold/turbo.
4DB89BEE-B233-43CC-BDCF-8A4EE656322F.jpg 90815EBC-C67A-44B0-86D4-EAECDEC028F9.jpg 13B0E2BD-E13C-4C4C-8FDB-08F00FBC2F5C.jpg
Jbulach
2,414
Sunman Indiana
View attachment 710264View attachment 710263View attachment 710262
Disappointing, was hoping for an on/off toggle switch for a throttle, mounted on the gear shift with all the other knobs...
Jbulach
2,414
Sunman Indiana
I really wanted a video of the pedals mounted to your desk, next to the running engine, while you practice rowing through the gears
Buffalobwana
180
Frisco Texas
A little disappointed in myself for not thinking of this first.
But ... Its not too late. Noooo, it’s never too late.
Buffalobwana
180
Frisco Texas
I believe I have sent you enough. So much, I forgot what I bought and what you were supposed to send!
I expect a card.
Swamp Donkey
The Engineer
126
Gray, GA
It'll be due for its first oil change before it even makes it in the truck going that route. He doesn't have to make the engine sounds with his mouth anymore so he can focus a little more on shift patterns, lol.
