M929/A1 Spare Tire Carrier Boom?
jaws4518
Cold Beer
141
Abilene, Texas
What is needed to complete the spare tire hoist etc...? There is no boom or hoist winch on a 929, just the flange plate covering the vertical tube. Do you attach the same hoist kit, or come up with something custom? Looks like a trip to Harbor Freight my be the best option. I need to be able to load and unload a spare tire. I would hate to get myself caught in a difficult situation.:shock:
Looked at all the TM figures on this subject. Ideas or real part info would be appreciated.
simp5782
Feo, Fuerte y Formal
9,260
Mason, TN
Weld a hook to the top of the bed side. This will allow you to hook a chainfall there to let the tire up and down with. Or bolt one. I have seen some added to dumptrucks I have picked up.
Even with the hook mount flush on the bed the tire will still come down beside the fuel tank. Or weld an arm to the underside of the bed that would allow more clearance if you wanted it
You could also put two u bolts under there to be able to add the hoist pole if you wanted to remove itScreenshot_20180605-125037_Google.jpg
Sent from my SM-G965U using Tapatalk
jaws4518
Cold Beer
141
Abilene, Texas
I can't believe it. The answer is right there and I couldn't see it. See, that why I ask because I was about to weld up a hoist arm with a HF chain hoist. I'll still do the hoist but weld the a hook to the underside of the dump bed head cover, then I can use the hoist for a variety of things.
Thanks!
simp5782
9,260
Mason, TN
If yours has the lifting eye rings in the headache board you can just attach a chain there and lay it over the side as well.
