- 6,863
- 707
- 113
- Stratford/Connecticut
I'll check on Monday to make sure it fits, and that we're allowed to spend the money. Do i need to wire directly to the battery bank, or have you found a spare harness to attach to in the past?View attachment 688810 4 1/4 thick. 24 volt fans. 16 by 23.5 inches. Running at 28 volts in the pic. Moves so much air it's hovering in the pic. Weighs around 15lbs. Hundred bucks plus shipping.
Thanks. Going to do the flush and refill first, and hope that works. Will look at the fan clutch lines tomorrow, and see what i need to do for that. If necessary. Suprman: will remember you for the fan, if neither of those work. The consesus of those affected by money going out was to flush, and change the fluid first, as it needs to be done anyway.The overheat light should have been disabled on all trucks per a MWO. It is generally faulty and unreliable. You have to realize all the worst evils on heat with these motors. Step one, get rid of your heat exchanger. You have an air to air transmission cooler in the grille. Just run it alone. Get rid of some engine heat this way. If you are having lots of overheating issues simply get a male JIC # 6 and make it a #6 on the opposite end and hook the fan clutch air lines together and make that thing come on all the time. It will also give you full blast on the clutch. Or go to a Horton style fan clutch control so you can turn it off and on as you want. Electric fans may work but you wont get a lot more cooldown. Other issue you could have is gunk in the radiator. May have several cross tubes stopped up.
Meow are you saying to link the two hoses from the shutterstat together meow?The overheat light should have been disabled on all trucks per a MWO. It is generally faulty and unreliable. You have to realize all the worst evils on heat with these motors. Step one, get rid of your heat exchanger. You have an air to air transmission cooler in the grille. Just run it alone. Get rid of some engine heat this way. If you are having lots of overheating issues simply get a male JIC # 6 and make it a #6 on the opposite end and hook the fan clutch air lines together and make that thing come on all the time. It will also give you full blast on the clutch. Or go to a Horton style fan clutch control so you can turn it off and on as you want. Electric fans may work but you wont get a lot more cooldown. Other issue you could have is gunk in the radiator. May have several cross tubes stopped up.
Yes. They are both #6 jic male fittings. You need a # 6 connector they are about $3.Meow are you saying to link the two hoses from the shutterstat together meow?
I seem to remember the fan clutch defaults to locked up with no air on it. am I wrong?
Thanks. Going to town today with old shutter stat to make sure i get it all right the first timeYes. They are both #6 jic male fittings. You need a # 6 connector they are about $3.
Sent from my SM-G935P using Tapatalk
All you need.Thanks. Going to town today with old shutter stat to make sure i get it all right the first time
Thanks. Also thinking of getting a plug to thread in where the stat is. Thinking it may leak coolant from the ports. Am i correct, or is that unnecessary?All you need.
Parker # 8 FTX-S
It is rare. It is just a half inch plug.Thanks. Also thinking of getting a plug to thread in where the stat is. Thinking it may leak coolant from the ports. Am i correct, or is that unnecessary?
