mike1976
- 5
- 3
- marshall mo
looking for the location in the TM for the electrical diagram I am having troubles downloading and reading pdf files with my slow internet
.looking for the location in the TM for the electrical diagram I am having troubles downloading and reading pdf files with my slow internet
What are you trying to do or what is your truck doing I can give you pin and wire numberslooking for the location in the TM for the electrical diagram I am having troubles downloading and reading pdf files with my slow internet
15 is spliced in with wire 81 that receives its power from the positive post at the starter solenoid. So just run you a new wire from there so it has full time 24vlost power to the light switch found the test procedure and tested wire 15 found no power there was trying to find where it gets it's power ended up running new power wire so the truck could be used
.hi guys
new here so i hope im not beating a dead horse.
Im having trouble loading the p2p. could someone guide me through the process?
thanks
