- 307
- 2
- 18
- York, PA
We just won a project where access is bad. I have budgeted two months rental of a crawler carrier. That's not cheap. I was wondering if the purchase of a M929 would be an ok alternative. I can't rent a crawler carrier that rotates 360, so that takes away one big advantage. Its not a rocky access, is relatively flat, open, straight, but narrow. Long distances to back up with either a truck or crawler carrier. So the main concern with the M929 would be wet ground on top. Would most likely never title the truck for street use.
The crawler carrier would probably do less damage to access drive, but would like to save on cost and could end up with a dump out of it.
Thoughts?
Thoughts?
