M929A1 axle ratio?
ccf460
granite falls/N.C.
M929A1 axle ratio?hub flip?
I am looking at a M929A1 dump truck for a parts rob for another project.
Axle ratio?
Transfer case model? hoping it's a T-1138
Thanks in advance
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
Axle ratio?
Thanks in advance
Almost all military trucks are 6.44s. And yes it is a t1138
Sent from my SM-G935P using Tapatalk
ccf460
granite falls/N.C.
Awesome, thanks.
I am looking at buying a running driving truck that I found to rob the axles and t case for a 12 valve cummins powered, air braked, crew cab F700 project.
Does anyone make lockout hubs for the 5 ton axles?
Also,can the rear hubs be flipped like a deuce?
98G
Former SSG
4,190
There's got to be a cheaper way to get a t-case and axles than to take a running driving dumptruck apart. Unless the rest of it is just held together with rust....
Consider selling to dumptruck intact and buying a 939series cargo truck to cannibalize. You may end up with a good deal of $$ left over...
