dsmith006
- 0
- 1
- Monroe, la
Hey guys! I'm back again, y'all helped me a lot last time with a throttle cable issue and a fuel tank swapping valve.
This time I've got another problem, my brake lights won't work! When I turn the switch to lights, everything seems to work fine, except the brake lights.
I'm not sure if the two red lights in the back are supposed to blink like turn signals, but they don't...(I would think they're supposed to).
I've got a manual on the truck, but I think it might just be an owners manual, it goes into detail on lots of things, but I can't find a complete wiring diagram for it.
Do these trucks have fuses in any particular location? I've traced all sorts of wires and see a fuse randomly placed but haven't found a fuse box.
I read on another post about checking the brake light switch on the inside of the frame rail, so I disconnected that and shorted the two wires, but still no brake lights.
I'm sure you guys have got a few things I can try!
Thanks very much!
David
Thanks very much!
David
