M929A2 Turn Signal Question
Postman515
46
Clayton, Illinois
I have a BMY 929A2 dump truck. The directional signal switch light comes on for left/right and hazard but doesn't flash just kind of dims . Is the turn signal flasher bad.
Suprman
707
Stratford/Connecticut
Did you walk around the truck and see if the blinkers are flashing as they are supposed to? It could be several things I would start with the simple ones like checking bulbs and go from there.
BKubu
1,255
Gaithersburg, MD
Like the others have said...it could be a number of things. Check the light switch...check the bulbs...check to make sure the turn signal switch on the steering column is grounded properly...make sure the lights themselves are grounded properly. If all of that checks out, it could be the flasher unit.
Postman515
46
Clayton, Illinois
The light switch is on. The light on the turn signal lever comes on and stays on it just doesn't flash. All other light functions work just no turn or hazard.
Postman515
46
Clayton, Illinois
Tested with voltmeter and have 24v going into flasher module and 24v back out but no flashing so im guessing flasher module is bad.
Postman515
46
Clayton, Illinois
Thanks for all the input. I ended up pulling the flasher unit out my m817 and trying it in my 929 and all the lights worked fine. So I now know the culprit is a bad flasher unit.
