M931 Transmission Selector Not working properly
D6c
14
IA
The transmission on my M931 shifts and pulls fine but the only problem is that when you put the selector in any other position besides 1-5 it just goes ahead and shifts like it was in the 1-5 position.
If, for example, I put the selector in 1-3 it should limit the trans to shifting no higher than 3rd gear....but it just goes ahead and shifts on up through 4th & 5th.
Been looking through the manuals and the P2P program but haven't run across any description of how the control works.
Has anyone experience this or can you tell me the likely cause? Wouldn't be a problem to run it like this unless you need to limit speed downhill by manually forcing it to stay in a lower gear.
Suprman
672
Stratford/Connecticut
You can pull the shifter up its 4 small bolts. Look and see if it's working properly. Check your fluid engine warm running in neutral. Might be something simple if not in the shifter assembly or cable I would pay the allison dealer the hour or so of labor might be an easy fix. Sometimes money well spent.
Will
Bandit02
Blind Bay, BC
You may just need a linkage adjustment.
The cable may have stretched. If you wanted a sure way to know if it's linkage or the transmission itself disconnect the linkage off the transmission and manually put it into each gear with it running (while the park brake is on of course and wheels chocked), it's not gonna go anywhere as the torque converter will just stall at idle until revved up. If you stick it in 1st and drive it and it stays in 1st then it's not the transmission, try this for all gears.
Cables do stretch over time or maybe it's something else you can see while under there.
D6c
14
IA
Thanks, I'll experiment a little with the cable adjustment and see if that helps.
