M931A2 Build
hirollin87
9
Raymond MS
Been meaning to put some pics out since I was close to finished with it. First I got rid of that junk aftercooler and installed an intercooler. As you can see I had to add a filler piece in between grille and hood. 4 inch aluminum intercooler tubes from silicone intakes. I installed a higher cfm filter and ran a donaldson scoop out of the hood in order to get rid of the restrictive stock setup. Sent pump and injectors to Seth Farrell who is dang good. HEMMT wheels up front. Slider civy 5th wheel. Auber egt, fuel psi and boost gauges. LED front and rear. New paint. Electric wipers. Dual alternators. Things I need to do are put bumper back on and plumb 2nd tank.
IMG_2644.jpgIMG_2631.jpgIMG_2632.jpgIMG_2638.jpgIMG_2639.jpgIMG_2630.jpgIMG_2645.jpgIMG_2641.jpgIMG_2643.jpgIMG_2629.jpg
74M35A2
313
Livonia, MI
It is worth whatever somebody will pay for it.
What charge air cooler did you use, and do you have any document temp drop by using it?
Jericho
69
Landaff NH
Nice truck ! What did you have done to the Pump and what was the resulting gain in power? I assume you are looking at the 916 to see an increase in HP ! Is the 931 still suffering from lack of pulling power ? is that why your looking at the 916 ?
porkysplace
1,487
mid- michigan
The alternator question or the air cooler question?
Gimpy was refering to post #1, which has no questions other than what it's worth which is wrote with all the info ussually found in a classified ad including the phone number ( why would you include a phone number in a post unless your looking to be contacted by non-members that can't post in thread or PM you )
hirollin87
9
Raymond MS
I apologize I fixed it. I am just in habit of putting number in case someone wants to talk rather than type. When I decide to sale I will post in right category.
74M35A2
313
Livonia, MI
Alts Chinese clones (corrected, they are not Chinese), which do work OK and very economical. A genuine 70 amp Delco 21Si prices at just over $500 each MSRP. Chinese clones are about $120ea. I have had several genuine Delco failures, and would almost recommend the Chinese one instead, actually. Are you running one 12v, or both 24v?
http://www.discountstarterandaltern...-delco-remy-alternator-21si-24v-70a-19010182/
Understood on the temps, too bad because we are trying to quantify these things. What type of charge air cooler and how did you remove/replace the stock factory intake mounted liquid to air cooler? Gut it or replace it with a different cover plate?
Interesting fix on the charge air cooler fit without moving radiator back.
Not sure on 931a2 pricing, but do know a case where a guy was offered $22k for a 923a2 and took it. Know of another recently paying $9k for a 923a2 with soft top and no cargo cover. Prices are up for now as auction sites dry up of them.
hirollin87
9
Raymond MS
IMG_1627.jpgIMG_1625.jpgIMG_1468.jpgIMG_1466.jpgIMG_1452.jpgIMG_1451.jpgIMG_1450.jpgIMG_1627.jpgIMG_1625.jpgIMG_1468.jpgIMG_1466.jpgIMG_1451.jpgIMG_1450.jpgIMG_1452.jpg
Alts Chinese clones (?), which do work OK and very economical. A genuine 70 amp Delco 21Si prices at just over $500 each. Chinese clones are about $120ea. I have had several genuine Delco failures, and would almost recommend the Chinese one instead, actually. Are you running one 12v, or both 24v?
One 12v and one 24v. Here are couple of pics.
Bought used intake off another 8.3
74M35A2
313
Livonia, MI
Cool. Nice job, thanks for the additional pics. Those alts are genuine Delco, the Chinese ones do not say "Delco Remy" on them, but the originals do have that cast into the back frame cover of them.
I like the size of the charge air cooler, but looks like it may not be the Volvo one? So, is the power at least a lot better? Engine looks nice and clean.
hirollin87
9
Raymond MS
Middle pic is tensioner pulley bracket. I had to reindex the tensioner when I put 2nd alternator on. So I made one that would essentially work for a lot of applications.
hirollin87
9
Raymond MS
I never drove it before the build. But I am very satisfied with it. You know how it is. You can never get enough power. HA! I am thinking about a m916. I am pretty sure cooler was out of international. I will look back.
Lukes_deuce
123
Long Island, NY
Nice build! Truck looks good and you have some nice fabrication skills. I bet between the intercooler and pump modifications she moves now! How did she pull with the trailer and wrecker?
Did yo ever find a part number for the intercooler?
