trooper632
- 5
- 18
- Utopia, TX
I'm not sure but I think the Fuel shut off solenoid might be bad on my M931a2 (8.3 motor). I tried to start truck today and it doesn't seem to be getting fuel, One tank was actually quite low on fuel so I thought maybe it didn't have enough and sucked air into the system. I took out air cleaner and it will start and run on either thought I could get it back primed running it. Wont stay running. Got to looking at fuel cutoff solenoid, and it wont retract when the battery and start key are energized, I have to manually push it in. But when I turn off the keys it pushes forward, like its suppose to. I also notice its quite hot to the touch. So two questions. 1. Will the run without it, or does it need it just to run the motor, and 2. I tried to bleed the system as per the TM's and there is fuel at the IP, but I couldn't get ant fuel at the injectors when I cracked one, my helper really didn't keep the truck running long enough with the either maybe. If it is bad who has them for sale that might read this, Thanks
