M931A2 wont shift to low range.
racing4funn
Chattanooga Tennessee
When I got the truck the shifter was disconnected so that might be a sign of what someone else knew. I reconnected it but it wont budge. My only guess is the button on the end of the shifter isnt working? Anyone been down this road and could give me advice?
1,168
Are you following the directions in the TM ?
swbradley1
Modertator
1,557
Dayton, OH
Are you pushing on the brake pedal when trying? The one sitting here won't shift unless pushing on the brakes.
Tow4
621
Orlando, FL
Try shifting the transfer case while moving. Put the transmission in neutral first. If you can't shift it to neutral while it's rolling, you have a problem.
I can shift the transfer case in the M929 while moving, but the transmission has to be in neutral. I've had to put the transmission in gear momentarily to spin it up to shift the transfer case if I wasn't quick enough shifting the transfer case after putting the transmission in neutral while moving.
Good Luck.
The TM has all the details.
racing4funn
I have tried the slow roll in neutral. Ive tried stopped in gear and out.. I think Ive tried while on the brakes but might have to test that one again.
What does the button on the end of the handle do? A lock out?
Suprman
654
Stratford/Connecticut
The button on the handle triggers a solenoid. There are 2 wires running along under the handle from the button. If you turn the truck power on without the engine running you can hear it click when you press it.
m16ty
210
Dickson,TN
Try shifting when the truck isn't running and has zero air pressure. If it will shift then, you're having problems with your interlock (which I suspect is the case).
In my opinion you'd be better off to just do away with the interlock. Look toward the front top of the t-case and you'll see what looks like a air cylinder end sticking out of the t-case that has a line running to the end of it. Take the line off and plug it. It should then shift much better.
racing4funn
Both interesting. I will look into these and get back
M35A2-AZ
381
Tonopah, AZ
That would be a good thing to try!!!!
1,168
From the -23-1TM,
TRANSFER CASE
35. HARD SHIFTING OF TRANSFER CASE
Step 1. Check transfer case fluid level (LO 9-2320-272-12).
Fill or drain to proper level as necessary (LO 9-2320-272-12).
Step 2. Inspect transfer case shift linkage for proper lubrication.
Lubricate linkage as necessary (LO 9-2320-272-12).
Step 3. Inspect shift linkage for bends, breaks, and missing parts.
If shift linkage is bent, broken, or has missing parts, notify DS maintenance.
Step 4. Check wire 586 for good ground.
Repair or replace wire (para. 3-131).
END OF TESTING!
randygk
Nampa, ID
When picking up our M923A1 at GL I tried to put it in low range and it would not go in. As I tried to move the lever I noticed sparking near the base of the lever. The wires were chaffed bare where it goes through the floor. Looks like it might be a common issue.
racing4funn
From the -23-1TM,
TRANSFER CASE
END OF TESTING!
Yea Im well past that trivia trouble shooting or I wouldnt have posted.. But thanks for your thoughts. some people will over look the obvious. Ive been setting on and playing with this problem for months.
Wire is good and tests good but I wasnt sure what it did or if needed and as others pointed out the design might be more trouble than good..
m16ty
210
Dickson,TN
I do this on every M939 truck I get my hands on. The interlock can be problematic due to faulty button, faulty wires, air solenoid not working, or sticking air cylinder. There's really no reason for it to be on there so I disable it.
wsucougarx
65
Washington State
I had issues with shifting my transfer case when I first got it. Turns out the wire leads from the shifter button were crossed and another wire under the cab was hooked up incorrectly. That switch operates an air dump valve so you can shift the transfer case. If it's hooked up incorrectly, the air won't dump, and will not allow you to shift with the air pressure up. Are you able to shift when the truck's air pressure is depleted?
One way to find out if the button is working is to build up air pressure, shut the truck off, turn just the battery switch on, and depress the button. If you hear an audible click from the back of the truck (usu accompanied by an air swoosh) then your switch is working correctly. If not, troubleshoot via TM's.
