Carlo
- 21
- 0
- palazzago italia
Pilot?I fly for a living. Sometimes I get blocks of time off that allow me to get some work done.
yesPilot?
That's kinda what I'm thinking. I would use a 3/4 steel drop plate that would be welded to the pintle assembley. It would be an inch wide on both side of the pintle and drop down below the pintle about 15 inches then cut a 2.5 inch square out and insert the hitch. Then make to more plates with the 2.5 inch square one on the end and one in the middle to support the hitch. Weld it all to the pintle and then put reinforcing plates on the assembly. I'm not looking to add any other supports to make it removeable with the pintle assembly.As you know I am also looking to add a 2 inch receiver hitch to my M931A2. Been looking at ways to fab one up. This past weekend my friend the welder came over and took a look. You are right a standard hitch will not work well. One of the main problems is how to run braces to the rear and still have the needed clearance for the rear axle and its associated plumbing. Here is what he came up with. He will use heavy plate for the job. He took a spare pintle hitch with him and will fab it up at his place. Removing the trailer electric connector without having to cut the wires is something I have done many times so that is not a problem
http://www.steelsoldiers.com/showthread.php?101670-M931-32-2-inch-receiver-hitch
That looks nice! I would expect no less from you Captian!Well I'm thinking about a standard trailer hitch install so I can pull about anything behind the truck. Since its a tractor normal solutions won't work. I've seen a couple of ideas that put huge plates on the back of the frame or alter the trailer itself. I'm looking for something that will look stock. This is the idea:weld 3/4 inch thick steel to the pintle base and put in a 2.5 inch receiver and weld supports that go back following the pintle structure. Limit loads to less than 15k due to the increased lever arm on the bracket.This would require removing the pintle assembly but would make it much easier to weld and set up the support structure. No relocation of lights, bolts right up with pintle assembly and no modification to the frame.
Awesome Truck, great workmanship I like it. I was thinking of bobbing a tractor but your truck looks great and a lot less work. Can you post more pics of the rear. I would like to know what section of the bed did you take out, could you give me measurements please. ThanksI don't think my rubber mud flaps are up to holding much![]()
I have enjoyed seeing your progress as you personalized this truck and made it "yours". Your attention to detail and craftsmanship with this build is to be commended. I see you've offered it for sale in the classifieds section; the new owner is going to be a proud new owner.
