m934 LED reverse lights & dual reverse cams
Suprman
704
Stratford/Connecticut
I set it up with the switch in the trans so when I put it in reverse with the engine running the rev lights and cam screen comes on. Dual cams are switchable on the screen and the rev cam system is powered via an extra accessory lead on the keyed ignition so it all turns off with the truck. Makes backing up the big behemoth so much easier.
Suprman
704
Thanks I am working on other stuff for this truck also. I am going to mount some HID floods up high just havent decided exactly where yet. And I have Hella H4 7 inch replacement for the factory headlights with 70/90 watt bulbs.
