- 3,218
- 383
- 83
- Tonopah, AZ
When we picked up the M936 at Barstow the front axle on the right side started leaking on the way home (320 miles).
I got around to working on it and here is the story.
Pulled the hub off and noticed the bearings had rust all over them and were about to come apart, I am sure of that.![Doh! :doh: :doh:](https://www.steelsoldiers.com/images/smilies/smiley_doh.gif)
Then I noticed the boot was not locked in with the ring and had water in it.
When I took the bolts off the bottom of the king pin housing and water came out and smelled bad. 2nd![Doh! :doh: :doh:](https://www.steelsoldiers.com/images/smilies/smiley_doh.gif)
I got things cleaned up and ordered new bearings. Pulled the axle seal housing out. That was a job!!! Next time I will just replace the seal and not pull the housing.
Tried to put in the new seal housing in but I could not get it to start in the axle. So I made a tool to help to get it started and press in the new seal.
Put the boot back on and installed the spindle ( used lots of grease!!)
Installed the new bearings in the hub and installed the axle. Put the hub on the axle and set the bearings. Yea almost done!!
I also took the left side apart and checked if it had any problems and put new gear oil in the diff.
The Moral of the story is check your hubs!!!
Yea!!
![Driver :driver: :driver:](https://www.steelsoldiers.com/images/smilies/driver.gif)
