M936 recovery
1,135
I think you're only the second person on SS who has covered their wrecker in the "factory" way-I think we have a UK member with an 816 who had the right cover on his.
Probably not a bad idea just to keep the cables dry and the hoses from rotting (further).
mdmorgan
AM3 U.S. Navy
1,085
103
Forsyth, Ga.
If it looks "factory" it was by accident, by chance I figured out that deuce bows and staves were just wide enough and tall enough to work, and I threw an old torn deuce cover over it. The cover should be a little longer but it covers almost everything, so it will work. And yeah I did it to keep the weather off of it.
mdmorgan
AM3 U.S. Navy
1,085
103
Forsyth, Ga.
Well, I finally tried out the hydraulics on her today. The front winch PTO did not want to engage with the engine running, sounded like grinding gears, so I engaged with the engine off then started it. The actuator for the wind/unwind was frozen, but with a little wd-40 and some light taps with the hammer, I got it moving. So, the front winch works. The rear hydraulics, when I engage the PTO the engine comes up on RPM on its own as it should, I shift the trans into 1-5 but I was not getting hyd power to anything. Upon further inspection and TM research I find that the PTO shift cable is nowhere to be found, so I need one if anybody knows where to find one. But, for now I'm going to make something temporary just so I can test the rear hydraulics.
1,135
Just make sure it's working before October.
:whistle:
73m819
327
gainesville, ga.
It looks like the 12SSGAR will be the year of the wreckers, A m936, a m62, and a m819 are at least at this moment scheduled to make an apperance
gimpyrobb
dumpsterlandingfromorbit!
27,786
760
Cincy Ohio
I'd like to see more pics of the truck in general. I don't think I have gotten to climb around on one of these newer ones yet.
mdmorganwife
15
Forsyth Ga
These are the parts we need. No NSN listed but here are the pics. On pic 1 the cable we need is #23, pic 2: #3 is the end of the cable and #5 is the bracket that was missing.
