ClintA
- 17
- 18
- Mule Creek, NM
So let me begin with we were using the M936 today putting together the final drive on a Dresser DT15 and all of the sudden the truck tries to take off. The T-case will not go in neutral, even when it is in neutral. I got under it and checked oil, all is good. It is hot where you can't hold your hand on it on top where the bearing is (short drive line) it is cool on bottom of T-case. I can put the case in high and it will pull forward/backward and I can't get it low at all. So when the handle says it is in neutral, the truck will pull forward and reverse. I let things cool down for lunch, still same thing (T-case is still hot) tried before I came home, same story. I am stumped, the T case is new, bought it from Castle Bravo not long ago and everything worked just fine all day yesterday and today until we were putting the final drive on. I mean it (the final drive) is hanging as we speak, I did boom down to take the load off but I need help in a bad way. Any ideas from you guys?
Can I remove front/back drive-lines so I can get the crawler back together?
If I drive it around some (that will be hard with boom up and cable out) to see if it will fix itself?
I will try it very first thing in the morning, the sun will not come up early enough. Thanks in advance, Clint
575-535-4359
575-535-4359
