Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
recently was using the crane on a m936a2 and everything functioned correctly until i took the pto out and put the transfer case back in gear, the transmission seems to be stuck in reverse in reverse and neutral, transmission locks up in forward gears like its still in reverse but trying to put it in a forward gear at the same time, anyone else have this issue?
Follow the wires at the back of the shift lever and unplug them. I had a M932 the wires came unplugged and I had to shut the truck off and bleed the air down to shift the transfer case until I found the problem. May not fix your issue but it's something to try.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
