M936a2 abs
funky winkerbean
9
whiting nj
I have a 936A2 with abs and the light is on. Was wondering if anyone knows what I can use to diagnose problem and where it gets plugged in at?
Suprman
680
Stratford/Connecticut
Did you check the 2 fused tucked under the drivers dash? There is a diagnostic plug under the passenger side dash. You need a specific reader for it though. How is your voltage gauge reading?
Suprman
680
Probably the control box clicking. The readers are few and far between. Check the fuses. Check your battery voltage overcharging alternator will kill the abs ecu.
1,174
If you have not been waiting for the abs to do it's thing before starting, or shutting off the truck incorrectly, you may have damaged the controller.
All in the TMs(which are free to download on this site and on several others).
