M939 Front Axle Shaft Hi-Tech
99nouns
17
Ocala, FL
Hello all,
I was fooling around GL and saw the following, previously I did a complete tear down knuckle boot job on my 927 and the front axle shaft that I had was with u-joint and when I saw this I was like wow, that's some hi tech u-joint, I wonder what the mechanics of that or how it works.
Is it actually dust/sand proof, like you would never need a Knuckle boot ever again?
And the ones I had was like this
Sorry mines are not very good pictures, I covered it so it wont pickup dust and forgot to snap a pic when bag was off.
But it did look just like a u-joint on a driveshaft.
Suprman
707
Stratford/Connecticut
It looks like the open part with the long shaft would be where the boot would go and the shorter shaft drives the hub. I could be wrong though.
VPed
315
Clint, TX
That is a constant velocity (CV) joint like what is on modern front-wheel drive cars and 4x4s with independent front suspension. It definitely needs a boot, more so than a U-joint.
Blarsen
Pg, utah
It is called a birfield Joint, it is what Toyota uses in the straight axle Land Cruisers, it requires the knuckle to be filled with grease and they also have a wiper seal like a 5 ton.
