m939 hard top back window
clydizzel
Carthage Illinois
Has anyone ever cut the back of the cab to fit in a full size truck back window so they can see better? I do alot of backing up and i think it would be nice to see better.
MtnSnow
15
NSL, UT
I installed rear view and front view camaras in my 923a2 and will do the same in my 925a2 as it makes backing up and parking in public lots without soldier B so much easier and safer.
goldneagle
1,417
Slidell, LA
Yep I agree that is what the mirrors are for. If truckers can back up semi's with only mirrors then so should we. You can always install a backup camera if you want to see behind the truck.
Suprman
705
Stratford/Connecticut
It takes time to adjust your mirrors and practice to get comfortable with the truck. You can add an extra curved mirror on the right side for added view. Make sure once you have them set how you like them to tighten the nut or the mirror will drift from vibration. I have rearview mirrors in my trucks if you position them right you can see out the back pretty well. Practice is the most important thing. That's why military truck drivers go to military truck drivers school and then practice driving at their unit.
Bighurt
46
Minot, ND
It's easier to use mirrors. The back window on every daycab I've run has only been clean for about 15m after dispatch, particularly in the winter. I don't even look out the back window of the M915.
I suggest adding after market convex mirrors, the little OEM ones aren't great. I'd much rather have 6 rd below.
