M939 series transfer case low range / front axle engagement
simp5782
Feo, Fuerte y Formal
9,486
Mason, TN
What does it mean when the front engages on my M925A1 but the light does not go on.
Bulb burned out. Bad ground for the bulb, bad power wire to the bulb. A number of things it could be.
Sent from my SM-G935P using Tapatalk
TedCat
Saline Mi
Can anyone supply me a local part number for the coil on the lockout solenoid? My valve works but the coil is cracked inside. Havent had luck yet. Thanks!
simp5782
9,486
Mason, TN
There isnt one that i have found. Just the whole solenoid. I have a good take off i can sell. Or you can just do away with it all.
simp5782
9,486
Mason, TN
'Big ASS Sign in the cab of the 900's says N E V E R use reverse in LOW range !!!!!!
Thats for people who don't know how to operate it in low range. Transfer cases blow in high and 6x6 or in low going forward. There is no pattern. You can use low reverse all you want if you use your head
