M939 tire clearance?
Buffalobwana
179
Frisco Texas
Bufflowwanna - I asked in another thread - but you may know...
I was told by someone that has and/or works on the 923 & 925 A2's - that said when airing down for 'Sand' on the CTIS the 1600's will rub. I was trying to wrap my head around the notion of how less air increases tire diameter.... unless the increased sidewall buldge rubs?? Do you know?
Hard to believe, but, possibly they expand outward a little? Hard to believe it's a significant amount.
I was told by someone who really knows tires, that you can not air a 16.00 down below 60 and expect to not have a flat the next day. Said they need 80 to keep the beads seated. And that you can't air these big 16.00's down without beadlocks. I trust him because This guy knows tires very well.
98G
Former SSG
4,866
What's the low pressure setting on the CTIS on the HEMTT series?
I suspect that the answer to that question will invalidate your expert's opinion...
Buffalobwana
179
Frisco Texas
Do tell? (I know you know!) I don't know what the low psi range (sand) is. Do HEMTTs run beadlocks? I have found them in HEMTT rims tires I bought from you. Do they always run them?
I try to soak up as much knowledge and info as I can from guys who have been at this longer than me. It's why I'm on this site. You know me, I pepper you with questions!
Castle Bravo
Hundredaire Socialite
231
Arizona
The HEMTT doesn't have CTIS, but the M1070 and M1074/M1075 PLS do and run 16R20s on 20x10 wheels similar to the HEMTT wheel. Some numbers -
M1070 Tire Pressure
Highway - 45 MPH - 75 PSI
Cross Country - 30 MPH - 55 PSI
Mud, Sand, & Snow - 15 MPH - 40 PSI
Emergency - 5 MPH - 30 PSI
M1070 Axle weights
Axle 1 - 17,620 LBS empty, 20,122 LBS loaded (w/46,000 LBS on kingpin)
Axle 2 - 7,291 LBS empty, 22,022 LBS loaded
Axle 3 - 7,050 LBS empty, 21,982 LBS loaded
Axle 4 - 7,030 LBS empty, 21,982 LBS loaded
