M939 Wiring /Lighting issue
texczech
Texas
The local rural fire department has a M939 with Lighting issues- Headlights, tail & turn signals don't work. Where can I get a repair manual to cover this problem/diagnosis or any quick tips on where & how to check? Thanks!
20,760
The TM's (Technical Manuals) are posted here. Free download. TM9-2320-272-24-4 has electrical diagrams with the full truck electrical on page 819. That page is attached below.
The turn signal (SignalStat) will generally last forever - but everything out on the back of the truck goes through it - so that is a good place to look. Reading your post a second time mentions headlights, so that points more at the 3 Lever switch... Has anyone made changes to the lighting recently? Like maybe adding or upgrading to LED's possibly?
20,760
Might want to insure that personnel understand how to use the 3 lever switch.
Check in the dash 10 manual you can download I think.
Good reminder @GopherHill
Here are the easy version of "Cheat Notes" for the 3 Lever Switch.
Brake lights for example DO NOT operate if the lights aren't in the "Service Drive" position texczech .
Micmada
211
Florida
Make sure the ground/bounding is good. I play with HAM radios and I have the same truck and they tend to develop rogue current through the frame from one piece of electric to the other.
