wsucougarx
- 65
- 48
- Washington State
M939A0 M939A1 Corner
I've been on SS for a couple years and feel like a newbie once again. Now that I'm diving into the family of 5 tons, I find myself searching for posts related to PMCS. So far I haven't found too much in the way of parts listings. With the huge influx of M939 family trucks hitting the market, I felt it fitting to start this thread. Looking to have this thread as a catch all for Filters, Belts, Seals, and whatever parts we need to get for PCMS. I know many of the parts are the same as with the M809 series trucks. However, not having owned a M809 I have no idea what to look for. I see there is a thread dealing with the M939A2's, but nothing for the A0 or A1.
Does anyone have the NAPA numbers for the belts, filters, seals, hoses etc.
Eriks does carry many parts but wanted the local part numbers for those got to have it now scenarios.
Thought I'd take the bull by the horns and try and get some links together![Wink ;-) ;-)](https://www.steelsoldiers.com/images/smilies/icon_wink.gif)
Check Valve:
http://www.steelsoldiers.com/5-ton-up/81288-m939-air-system-check-valve.html
Control Box (AKA Black box):
http://www.steelsoldiers.com/5-ton-up/81220-m939-black-box.html
Belts:
http://www.steelsoldiers.com/5-ton-...drive-belt-replacement-need-part-numbers.html
Oil, Tranny, Air, Fuel Filters:
http://www.steelsoldiers.com/5-ton-up/38814-m939-filter-info-share.html
http://www.steelsoldiers.com/5-ton-up/5488-napa-part-numbers-needed-nhc250.html
http://www.steelsoldiers.com/5-ton-up/6905-first-oil-fuel-filter-change-m812-nhc-250-cummins.html
http://www.steelsoldiers.com/5-ton-up/76700-m925-filter-cross-reference.html
http://www.steelsoldiers.com/5-ton-up/12688-m809-m939-5-ton-air-filter-elements.html
http://www.steelsoldiers.com/5-ton-up/77537-comments-servicing-my-newly-acquired-m923.html
http://www.steelsoldiers.com/5-ton-up/37679-filter-numbers-900-series-250s.html
OTHER TOPICS:
Radios:
http://www.steelsoldiers.com/military-radios-other-electronics/81191-m939-series-radios.html
http://www.steelsoldiers.com/milita...cs/13268-rt-524-radio-installation-setup.html
Videos:
http://www.steelsoldiers.com/5-ton-up/80489-some-m923-videos.html
Allison MT 654 CR transmission:
http://www.steelsoldiers.com/5-ton-mods-hot-rodding/77647-allison-transmission-m923a1.html
http://www.steelsoldiers.com/5-ton-up/72226-m923a1-transmission-fluid.html
http://www.steelsoldiers.com/5-ton-up/77746-allison-transmission-fluid-research.html
http://www.steelsoldiers.com/5-ton-up/76902-m923-trans-prob-please-help.html
http://www.steelsoldiers.com/5-ton-up/74201-939-allison-problems.html
http://www.steelsoldiers.com/5-ton-up/72463-m923-reverse-shifting.html
Brakes:
http://www.steelsoldiers.com/5-ton-up/81036-m923-spring-brake-overide.html
http://www.steelsoldiers.com/5-ton-up/79389-m923a1-abs-light.html
Transfer Case:
http://www.steelsoldiers.com/5-ton-up/83799-m939-transfer-case-air-lines-installed-wrong.html
http://www.steelsoldiers.com/5-ton-...fer-case-low-range-front-axle-engagement.html
http://www.steelsoldiers.com/5-ton-up/15565-m-900-series-failures.html
http://www.steelsoldiers.com/5-ton-up/38873-m923-transfer-case-problem.html
http://www.steelsoldiers.com/5-ton-up/77309-923-transfer-case-wont-shift.html
http://www.steelsoldiers.com/5-ton-up/76019-m-923-transfer-case-not-shifting.html
Towing Procedures:
http://www.steelsoldiers.com/5-ton-up/79668-m939-series-towing-procedures.html
More Power:
http://www.steelsoldiers.com/5-ton-...m939-series-trucks-allison-transmissions.html
Recovery:
http://www.steelsoldiers.com/military-vehicle-road-trips/79651-sparta-m923-recovery-trip-home.html
http://www.steelsoldiers.com/members-rides/75273-new-m923-finally-here.html
http://www.steelsoldiers.com/conversations/78149-bighurts-m925-recovery.html
http://www.steelsoldiers.com/5-ton-up/77928-truck-recovery-today-ft-meade.html
http://www.steelsoldiers.com/milita...overy-huntsville-alabama-phoenix-arizona.html
http://www.steelsoldiers.com/conversations/72446-mccoy-m923-recovery.html
Tires:
http://www.steelsoldiers.com/5-ton-up/35402-m923-w-1600-tires.html
http://www.steelsoldiers.com/5-ton-up/68974-pics-m923-oversize-super-singles.html
http://www.steelsoldiers.com/5-ton-mods-hot-rodding/83866-m923-925-16-00x20-tires.html
Other:
http://www.steelsoldiers.com/5-ton-mods-hot-rodding/81491-straight-stacked-my-m923.html
http://www.steelsoldiers.com/5-ton-up/81589-923-batteries.html
http://www.steelsoldiers.com/5-ton-up/79177-looking-923s.html
http://www.steelsoldiers.com/5-ton-up/76337-m923-recovery-towing-checklist.html
http://www.steelsoldiers.com/5-ton-up/80031-m923a1-insurance.html
http://www.steelsoldiers.com/5-ton-up/79005-m813a1-advantages-over-m925.html
http://www.steelsoldiers.com/5-ton-up/77967-m923-fuse-panel-location.html
http://www.steelsoldiers.com/5-ton-up/76535-oil-leak-pressure-question.html
http://www.steelsoldiers.com/5-ton-up/78122-water-pump-question.html
http://www.steelsoldiers.com/conversations/77599-m923-converting-24volt-12-volt.html
http://www.steelsoldiers.com/5-ton-up/77489-m923-air-leak.html
http://www.steelsoldiers.com/5-ton-up/77103-emer-engine-shutdown-help-reset-fuel-shut-off-valve.html
http://www.steelsoldiers.com/5-ton-up/76624-m923-vs-m923a1.html
http://www.steelsoldiers.com/deuce/...-m35a3-m923-couple-more-questions-newbie.html
http://www.steelsoldiers.com/5-ton-up/72190-put-new-style-leds-my-m923-but.html
http://www.steelsoldiers.com/5-ton-up/71750-appels-m923.html
http://www.steelsoldiers.com/5-ton-up/69000-m923-925-question.html
http://www.steelsoldiers.com/5-ton-up/82397-cummins-pt-part-s-give-back.html
http://www.steelsoldiers.com/5-ton-up/83437-red-river-army-depot.html
Check Valve:
Belts:
OTHER TOPICS:
Radios:
Videos:
Brakes:
Transfer Case:
Towing Procedures:
More Power:
Recovery:
Tires:
Other:
