dawico
- 1
- 18
- Lampasas,TX
I am in need of axle oil seals for my 923a2. I need to replace all six seals as they all leak and are getting worse. I assume these are also called pinion seals. It is the seals for the shafts that run from axle to axle. The TM says "17010PAFZZ5330-01-023-0269A-1205-U-78500SEAL,PLAIN,ENCASED" which includes the NSN and part number.
While I am at it I need to order two boots for the front axle, preferably zippered. Looking for recommendations on who to order from to get everything I need. What grease works well to install the seals and for the front bearings? Is there anything else I should replace while I am in there? Obviously I will check the bearings and such.
I prefer to do business with members here if that is the best way to go.
Any tips or tricks? Both parts seem pretty straight forward according to the TMs and my searches but info on the pinion seals is lacking.
As always, thank you SS in advance.
