74M35A2
- 315
- 83
- Livonia, MI
Bought and installed a Fumoto oil drain valve in my M925A2 (Cummins 8.3). Not sure I like it yet, 50/50. Find myself looking at the oil pressure gauge often now. It is nearly solid brass and located above the front axle, so something would have to protrude up and into it's cavity similar to puncturing the oil pan. Stock drain plug is steel with a copper gasket, built in magnet, 11/16" hex (maybe metric). Fumoto is 3/4" open end wrench, paper gasket. I added a cap to keep it clean. Main objective is to connect a hose to better control the arc when draining hot oil. Bought it on eBay. Not sure I trust it yet, may be giving it away in the free section at next oil change. Orange corded connector above it is 120V oil heating element which the pan has a port to accept.
