M939A2/MT-654CR Air to air cooler
Steelreaper80
96
Indianapolis IN
I was wondering if anyone has upgraded the transmission cooler on these trucks. What would you recommend? Cranking the power up this year and will be around a consistent 50,000 lbs plus. Any recommended parts, pics would be appreciated. I am trying not to fry the Allison. I kind of like it......
Lukes_deuce
125
Long Island, NY
Your going to need a big cooler with a fan. I bet Simp sent you a good idea, as he has been there and done it. Just remember the EGT wills get hot when you turn up the fuel, then add in a lot of weight and see them sky rocket.
silverstate55
Unemployable
2,124
1,078
UT
My 931A2 has been a workhorse for me; I turned up the fuel just a little bit, and increased the airflow (the air filter with the wire cage around it) which made a HUGE difference in reducing EGTs. I flushed the trans oil out and after complete filter changes filled it with Dexron III. It pulled a 53K-lb load up the Tehachapi grade in August heat with no issues; speed was reduced to 1st gear up one stretch but there were no overheating issues with anything (I keep a close eye on EGTs, as well as engine & trans temps).
My heaviest load was 58K-lbs between NV & southern Utah; this truck has made several dozen trips loaded up the mountain passes to our property in southern UT, where it currently resides. The first trip was when I discovered that the fan clutch wasn't engaging....but after that was fixed, I never had another issue with this truck. It's pulled & hauled reliably, even with a broken low-range gear in the transfer case (to be fixed soon).
Just with the minor tinkering I've done to the 6CTA motor, I've really livened it up & gotten a lot more pep out of it, making the truck a real workhorse. What Wes did with the MRAP radiator/cooler combo is even more useful; if I keep my 931A2 I'll do this to lower the EGTs even more and make it even more responsive over the long term.
