M939A2 tranny fluid
pigpen60
127
foley/missouri
I dont know whats in it currently, I was told it wasnt showing on the D/S and that I needed to figure out what to use. So if its ATF I use Dextron? and if its Motor oil I use 15/40?.
juanprado
3,204
Metairie/La (N'awlins)
Change the spin on filter under the hood. Probably needs it anyway and you will know which. Cheap NAPA 1268 or wix 51268 and a qt of whaever fluid you have. Can not remember if it has a fluid sample port also?
fpchief
229
South Alabama
Not sure what fluid you are going with but another member found a good deal on full synthetic ATF buckets with me off ebay and also Napa sells buckets of dex 3 for about $65.00
