M997A2 is now in my fleet
spankybear
976
WA
Nice.. did you have it built or actually find one?
I suspect some folks would love actual dimensions of it to produce their own.
I found it from a guy in California. It is brand new and I believe its a reject. The holes for the hinges are on the wrong side. They must have put the wrong side in the brake to make the bend. The sent it down the line and welded it. Nothing that can't be fixed...
I just need hinges now!
spankybear
976
WA
Found hinges... WOW open wallet and pour out money... So the steps, hard doors from West Kentucky Surplus the hinges and the antenna mount cost about the same price as the winning bid...
Need to do some work on the steps, then on to making the rear doors. After that paint...
spankybear
976
WA
Looking for parts for the bottom latch on the boor. There's a thing (number 14) that I can not find. So time to make my own. This is the first time I used fusion 360 and I design up a part using the dimensions from here . I will 3D pint the first draft to see what it will look like. I will also need part 13 that I believe is just bent out of some sheet aluminum... should be easy enough. I'll post pictures of the part when I get it printed.
