M998 6.2 Water pump/fan clutch help please
McSpeed
293
Palmer, AK
Hey guys - first post. I'm not understanding the instructions for how to get the fan clutch off a 1988 6.2 M998.
I pulled the cooling module as it needs cleaning, detail, etc. The water pump is shot.
I got the hydraulic link off (1/2 nut in the center).
I can't get the pulley to line up with the clutch bolts through the holes.
I need to get the clutch to disengage but don't understand how to do that,
What am I missing?
dilvoy
25
San Francisco, Ca.
You can loosen the small bolts at the rear side of the hydraulic clutch a few turns then rap the assy with a plastic hammer to shock it a bit and then you should be able to hold the pulley and rotate the clutch as needed.
McSpeed
293
Palmer, AK
Awesome! I just went out there after reading this and saw the small bolts. I'm going to give that a shot in the morning.
Can I get a rebuild/seal kit for that unit somewhere as well?
I'm also thinking replacing the fan now might be a good idea. I've read stories of them breaking. Looks like a miserable job if all you were doing was the fan.
McSpeed
293
Palmer, AK
Got the bolt trick to work.
I also spent hours and hours pressure washing and cleaning the radiators as the were caked in mud. What a mess!!!!
Now that she is clean and drying I’m takinf a break. New pump will be here next week.
Still need to find a seal kit for that fan clutch. I’m afraid I buggered it up. Probably why the air trick wasn’t working.
NormB
116
Hampshire, TN
Used to be kits available, there’s an NSN for them, no one seems to have them in stock.
I tried locating all the seals/bearings going by the parts list, found one part one place, two at another, bearings somewhere else, S&H plus parts and no o-rings was just too dauntingn a task, so I have a pretty large paperweight on hand, if I ever decide to give parts shopping a go again. Would be nice to rebuild one, just for fun, and a spare.
Norm
Action
1,563
East Tennessee
you may need a fin comb now after pressure washing the cooling stack.
