M998 Battery Shutoff kill switch- My final setup with pictures
Sintorion
14
Fla
I am curious is there is anything that draws constant voltage that is getting denied with a cut off? Obviously there isn't a clock or a radio, but anything else?
MOOSERABBIT
Morgantown, WV
if you have a clock or some other electronic device, you can wire a jumper across the cut off with a small 5 amp fuse, it will keep the clock going, however if someone were to attempt to start, it would blow the fuse, and kill the truck.
