M998 fan removal question
rcamacho
818
Bainbridge Island Wa
Read the TM.
Four recessed holes to access the mounting bolts. Fan clutch may need to be released in order to align the holes to bolts. Use air pressure to do so. TM covers this.
I’ve recently replaced the pump on an 1151A1 so the procedure is top of mind
Mogman
8,287
Papalote, TX
Like he said, there are 4 cap (allen head) screws that will line up with the 4 holes, you will probably have to put about 90psi on the clutch fitting to release the clutch then carefully align the cap screws with the holes and remove the air.
gtodan
45
Marion, Iowa
Good idea while you have it off to check the clutch seals, etc. Small impact works wonders. Check everything as you go. Take your time. Use your TM. Check twice, replace once. You wont have to tear it all apart again. Just replaced mine a couple months ago. Shaft sheared away from impeller. It overheated a bit fore I got it off the road. Now I'm replacing the Glow Plug Controller. HMMMM?
