WhoMe08721
- 123
- 43
- Bayville/NJ
Hey Guys,
My (M99
is always hard to start with cold engine in colder weather. I have replace all glow plug last year. I have tested the system by connect a amp meter across the batteries and with the glow plug cycling I see a draw around 89 amps. Also check ohms resistance on all glow plug they check out good. When I turn the start switch to run the wait to start light comes on for around 9 Sec. and I can hear the relay clicking under the dash too. When the truck dose final start the Glow plug system is cycling normal with pulse for 1 second and an off pulse for 15 seconds. I have also replace the fuel filter and checked the cold advance solenoid switch and solenoid there is power to both and I can feel and hear the solenoid pulling in. The only way I can get the old girl to start is by pushing on the accelerator pedal. Final the truck dose blow white smoke at first but that cold be it is cold out and diesel don't like cold.
My (M99
