M998 HMMWV Frozen Tailgate Hinges
kc5mzd
Texas
I think iI am going to go out and open and close my tailgate several times just to make sure it doesnt freeze up !!!
knighthawk
Matthews, NC
Don't you hate it when someone leaves you hanging and doesn't tell you the end of the story ?
Well after trying every thing else a second and third time ( heat , solvents, hammer and punch etc. ) I decided to give give Tobash's acid method a try. I removed the tailgate from the Hmmwv . Since the hinge is riveted to the tailgate I soaked each hinge individually in diluted muriatic acid. After soaking the hinge I rinsed off with water and placed it in a heavy duty vise and wiggled it until I got movement. I the soaked it in acid again for a couple of minutes , rinsed it and did the other one the same way. I then bolted back on the trick and soaked it with PB Blaster and moved it up and down until I had full movement. I wasn't counting but it mu
knighthawk
Matthews, NC
must have been 100 times. I am not satisfied with how smooth it is yet, so I will continue to spray it with PB Blaster and move it every couple of days,
Tobash, Thanks for the good advise .
