M998 how to replace horn button wire in steering column for aftermarket steering whee
Lazboytt
Michigan
Hello
I just replaced the steering wheel with an aftermarket steering wheel and would like to connect the horn wire. Does anyone know how to remove the horn wire from the steering column so that I can connect a solid wire to the new horn button? Or does anyone have any other ideas on how to connect the horn wire on an aftermarket steering wheel?
Lazboytt
Michigan
Do you know how to remove old wire from the middle of the steering column? That is what I was thinking remove that wire and put a solid wire up to the horn button but I am not sure how you remove that wire from the center of the shaft.
Lazboytt
Michigan
Does the wire just pull up from the top side? Because right now the horn button pushes into the shaft where it touches the wire.
porkysplace
1,496
mid- michigan
Not many of us bling the HMMWV's out .
Why can't you use the existing wire. Can't you add on to it ?
He wants to pull the wire out of the column , I'm guess he wants to use something like this.
https://shop.advanceautoparts.com/p/dorman-conduct-tite-electrical-switches-specialty-horn-button-flush-mount-ac85929-85929/5470854-P?searchTerm=horn+buttons
Technical Manuals for the HMMWV can be downloaded for free here;
https://www.steelsoldiers.com/showthread.php?78861-TM-s-for-the-M998-series
Lazboytt
Michigan
Hello
If anyone needs to know all you do is pull out the spring and then you can pull up the rubber with the wire attached. I used a wood screw and lightly screwed it in to pull up the rubber with the wire.
