M998 Humvee Running Light, Headlight, and Turn Signal Issue
Lit_Armo
9
California
Hi everyone just want to share another update on my turn signals,
Everything was good until one day they started acting up but I fixed it again!
The turn signal lever has a big circle gasket obviously seen once you open it up, its a rubber ring the goes between the metal contacts part and main body. So mine had gotten squished or was just old and flattened out from the years. My pops found a thicker gasket the same diameter from a gasket store nearby, about .2mm-.3mm thick, and replacing that fixed my turn signals.
The issue was the metal contacts were not touching enough with the old gasket as it was too flattened and old, the new one allows the contacts to firmly touch.
