ldmack3
- 1,740
- 93
- N. Central Idaho
While waiting for my parts (heads magnaflux was good) I'm back on the tranny and the chipped tooth.
Pulled the top and the 1st/rev gear is where that big chip came from. No biggie, will also replace the 2/3 synchro. So pulled jackshaft and seal and am down to pulling that bearing so I can lift the shaft out.
TM says to tap from the front on the shaft but that is with it sitting on a bench.
Edit: Mine is still in the truck.
I used a rubber mallet on the next forward gear to see if it would easily move but nothing. Can't get enough of a swing to put much on it. Probably a good thing.
How is everyone getting the bearing out enough to use a puller?
