Major Coolant Leak Don't Know Where!!!! Big PROBLEM!
gt1009
st.charles,IL
So i was on my way to the pet store to get some crickets for my little brother when i suddely start to hear a hissing noise whenever i let off the gas. The truck is running fine but I decided to pull over and check it out. When I stop all my coolant proceeds to pour onto the pavement and my engine has steam coming off of it for half an hour afterwards. I don't know what happened, as the leak seemed to be coming from behind the block or right on top, as there was evicence of spray on the firewall right behind the block, and underneath the air cleaner i could see a big puddle of coolant. I also noticed the remnants of a large drip coming from underneath out of a hole in a semi-circular something right in front of the transmission pan. AAA is towing it to my house now for a better look, but has anyone had this happen to them, or does someone think they know what is happening here?
Thanks,
acetomatoco
9
RE: Major Coolant Leak Don
Does your little brother eat the crickets live or dissect them first? Your leak sounds as simple as a heater hose...if so, you loop one into the other using your onboard tool set and add a couple of gallons of pond water using the empty soda cans from the back seat and off your go... ACE
gt1009
st.charles,IL
haha, I think it's a little worse, as I pulled the air cleaner yesterday and there were no hoses, but a big puddle of coolant on top of the block with a screw and a nut in it. I will siphon it out today to see what I can see.
dilvoy
25
San Francisco, Ca.
There are two coolant block off plates that are at the rear of the engine. They are located where the coolant crossover attaches at the front of the engine on the cylinder heads, but at the rear. One is blocked off with a flat plate and gasket and the other has the glow plug temp sensor threaded into it with a bushing. One of these may be the cause of your leak.
gt1009
st.charles,IL
That is exactly what it is. It is the flat one that doesn't have the sensor. I think it needs a new gasket. Thanks a lot!
dilvoy
25
San Francisco, Ca.
It's the harder one to get to, but if you loosen the vacuum pump and rotate it towards the drivers side you can work fairly easily on the block off plate. Don't forget to tighten the pump after your finished.
