- 1,707
- 1,779
- 113
- Nova Laboratories, WA
Tenative plan, is to ditch the primary fuel filter, and replace with an inline 100 micron reusable filter, then switch the factory secondary fuel setup into 2 spin ons using the 4770 base. I haven't decided if I'm gonna do a parallel setup with 2 micron filters, or a series setup with 10 micron then 2 micron.
All the literature I'm finding is showing the deuce at 1 GPM flow rate, which of course, most of which goes back into the tank through the return line, which basically means I'm gonna be polishing my fuel.
I plan on running a LOT of WMO though, so I need a good filtration system OUTSIDE the truck, so I'm not constantly replacing filters ON the truck.
There's no convenient list of all the fitting types and sizes for connections, so it's gonna be fun.
I've also been looking for 1/2" fuel line and holy crap is it expensive. I prefer using lines I can replace. Kinda hard to patch a hole in a steel fuel line on the side of the road (OK, not THAT hard)... But easier to grab a length of rubber/EPDM line, and splice it in or just outright replace it. Most of the stuff I'm finding is AN8.... and I'm looking for plain tubing I can attach to a barbed fitting with an oetiker clamp.
