devilman96
- 18
- 0
- Boca Raton, FL
Lax... In digging through some PN's and using what houdel posted for the intake here is your stack PN's (with some options)... One thing I didn't agree with is the exhaust elbows on an intake since you need them 100% sealed and water proof... Silicone, welding, etc are options but I would prefer rubber myself.
Rubber 4"X4" 90 degree intake elbows Napa PN 36171... you would need 2 at 15.49ea
4" X 60" OD - OD Aluminumized exhaust tubing Napa PN 45339 This would "work" but would not be the best thing if the job. 1 at 53.99ea
Or....
4" X 10' OD - OD Aluminum intake tubing Napa PN 49200.... Better choice between the two tubes. 1 at 114.90ea
Or...
You could prolly sub PVC for this but.. Err.. I dont know if I like that idea and I dont know if the elbows would fit it...
4" Stainless clamps for 90 degree elbows Napa PN 36204... You would need at least 4... 5 if you want to change your cap clamp to match at 5.99ea..
4" Stainless flat clamp (wide exhaust clamp) Napa PN 33961... Intended for fabbing a mounting bracket to your exhaust bracket 1 at 9.14ea
Everything was "S" class (special order) from my local store so I would assume most places would be the same and pricing would vary pending locations and such...
I will work on the internal PN's as i have time...
Or....
Or...
