bguy193
- 3
- 18
- Farmersville,IL
I have been searching for tool sets and decided to improvise. I found a garden tool sale at the local hardware store and went shopping. Every tool was $10 or less.
1)...The Pick Mattock did not need to be modified just painted. It has a plastic crown on the handle, which I found to be no big deal, but it can be replaced with a full wooden handle in the future.
2)...Standard axe handles are a bit long and will not allow the shovel to sit down properly in the tool rack so it had to be shortened 1-3/4" You can see the cuts I made in the pic below.
3)...Every one knows that a standard shovel is too long and will never fit in the rack as is. The handle on the shovel had to be shortened 4-3/4" then I had to reshape the shaft to accept the grip back onto it. I drilled new holes in the shaft and re-pinned the grip to the shaft....... Refer to pic below.
4)...Then I prepped and painted everything.![Thumbs Up [thumbzup] [thumbzup]](https://www.steelsoldiers.com/images/smilies/icon_smile_thumzup.gif)
